ExxEditor
XML editor based on XML Schema.Presentation
ExxEditor is a XML editor based on XML Schema.
How it works
ExxEditor generate a human comprehensible user interface for editing XML file, by using a XML Schema file.
ExxEditor is developed by the INRIA Digiplant team. The Digiplant team works on a functional structural plant growth model. This model has complicated input parameters. To store these parameters we use XML. But the XMl file format is hard to read or modify for a normal human being. So we have developed the exxEditor that gives us a beautiful and human usable interface to modify our input parameters.
Objectives and Limitations
- Edit XML file.
- Valid the XML file using a XML Schema.
- Easy to include in an existing application.
- But do not follow all the XMLSchema W3C recommendation.
Test it now
First you have to download and install ExxEditor.
Then you have to use an XML Schame file. You can use one of these example files: example1, or example2. To learn everything about exxEditor see the documentation.
License
ExxEditor is a free software, its license is CECILL-C (LGPL like). The source code is downloadable at this address: gforge.inria
You can find the license here: CECILL-C.
